33 perm 4 - Access to water pump pulley
GBSOD
PostPosted: Thu Oct 09, 2003 8:27 pm    Post subject: 33 perm 4 - Access to water pump pulley Reply with quote
33 16v boxer cloverleaf permenant 4.
To replace the waterpump, do you have to dismantle the cam belts? Or is it possible to work around them with care?
Cam belts only replaced 10k miles away.
many thanks
GBSOD
'Northern Soul... a way of life'
johnboy
PostPosted: Thu Oct 09, 2003 9:11 pm    Post subject: Re: 33 perm 4 - Access to water pump pulley Reply with quote
[quote="GBSOD"]33 16v boxer cloverleaf permenant 4.
Hi there,
you will have to take belt off on n/s, and rad out to do the job.if you look on older post's you will see how to time it up,it's easy to do,trust me i've been there,the water pump is a bitch to get out,you will proberly have to smash it out that's what i did when i had an 8v before the 16v conversion.hope that help's and welcome Cool
all the best
john
WODA WE NEED? MORE POWER!!
1999 freestyle superjet
GBSOD
PostPosted: Thu Oct 09, 2003 10:39 pm    Post subject: water pump blues Reply with quote
thanks for the advice, i'll get the hammer out of the toolbox.
cheers
GBSOD
graeme
PostPosted: Thu Oct 09, 2003 11:32 pm    Post subject: Water pump Reply with quote
I remember a guy did post in the last couple of months that he wangled the water pump out with the cam belt in place.
Might be easier to rebuild Wigan Casino!
16v p4 In pieces.
johnboy
PostPosted: Fri Oct 10, 2003 1:08 pm    Post subject: Re: Water pump Reply with quote
Hi again,
i did that with an 8v, but i would'nt risk it with a 16v. i just slackened the tenchener and wacked the pump out,but i wont do that again,i was lucky
all the best john
