protune /33 1.7 road racer
Goto page 1, 2  Next
richalfa
Location: southampton/england...under your mothers bed!
PostPosted: Tue Dec 09, 2003 4:31 am    Post subject: protune /33 1.7 road racer Reply with quote
i thought my 33 would intrest some of you,its taken me 3 years to build and is a trackday car ,but gets driven hard on the road,it started of as a standard 1.7 16v which was latter converted to carbs,but now its a normally aspirated 1.7 8v and i have done all the work myself at a low cost under 8k(Including buying and 2 blown up-engines,1 due to a 20pence part!)
it has very little standard stuff left ,everything has been altered,but remain's very road friendly and a starggering fuel economey 40 mpg+
it is very responsive in engine performance with a flat power delivery,and pin sharp steering and handleing and i have had some brilliant trackdays with it ,leaving lots of supercars standing too! Smile
for more info EM me at protune (richalfa.33btopenworld.com)
mawhawhawhaw!!!
richalfa
PostPosted: Tue Dec 09, 2003 4:40 pm    Post subject: alfa 33 1.7 16v pics Reply with quote
mawhawhawhaw!!!
richalfa
PostPosted: Wed Dec 10, 2003 1:43 am    Post subject: alfa 33 1.7 16v pics Reply with quote
heres how it all started!
and then this started to happen........
leading to this....
mawhawhawhaw!!!
richalfa
PostPosted: Wed Dec 10, 2003 2:01 am    Post subject: protune /33 1.7 road racer transformation Reply with quote
a few more pics of this project,and some info
ENGINE
1.7cc 8v na/ engine
reprofiled cams
idf 40 carbs
fully ported and flowed heads,standard 40 mm valves
16v pistons
baffled sump
solid lifters
oil cooler
magnacor race ignition
standard bottom end fully lightend and balanced
stainless exhaust system
full s/steel braided hoses
ngk race plugs
TRANSMISSION
1.2 gear ratio 5 speed box,armtech full throttle gear shift
SUSPENSION
lowered springs
koni front/rear ajustable struts
with powerflex bushes
non hydro rack
BRAKING
standerd calipers with all round disk conversion,standard pads (ferrodo)
s/steel braided hoseing ,hydro handbrake,bias valve
TYRES
205/40/17 toyo rubber
CHASSIS
fully lightened shell seam welded and strengthend
full aerodynamic bodykit
alloy race tank,seats,harnesses,
ap22 data logging ,
PERFORMANCE
145 bhp 135 lbf of torque
0-60 6.0 seconds top speed 125+
mawhawhawhaw!!!
Peter D
PostPosted: Wed Dec 10, 2003 9:16 am    Post subject: Road racer transformation Reply with quote
Where are you using the car?
175 flb (lb ft) is not technically possible with 1,7 and non force-feed (no turbo, no supercharger). I suppose, that you mean 175 Nm, which is also very good, since you only find a handfull of factory vehicles, which can deliver more than 100 Nm/liter.
Peter (DK)
richalfa
PostPosted: Wed Dec 10, 2003 3:07 pm    Post subject: alfapics Reply with quote
thats what is says on the rolling road torque curve ,i will put it up on hear for you,i was sceptical myself! Very Happy(copy of rolling road test to follow)
its used for everyday on the road ,all though i somtimes use another car,because its a bit bumpy !!like driving a small van
i use it on the track about 10 times a year
mawhawhawhaw!!!
richalfa
PostPosted: Wed Dec 10, 2003 5:24 pm    Post subject: Re: Road racer transformation Reply with quote
Peter D wrote:
Peter (DK)
any ideas on the torque then? as it does say 175lbf of torque
ive had few problems with a slipping clutch,but it will soon be sorted,then i should be able to get the 0-60 mph time down a bit(under 6 seconds)aided by the full throttle gearshift,theres more to follow soon as its due a rebuild,and im going to get some bigger valves and sort out the ignition to
as ive had a few over advance problems also top end fuel starvation,im also going to get some verneier pullys as the cams arnt properly set up,im hopeing to have over 150 bhp out of it in the next few months ,its just down to funding it !
mawhawhawhaw!!!
paddy granger
PostPosted: Fri Dec 12, 2003 8:13 pm    Post subject: Reply with quote
Interesting torque / power curves!! What happens at 3000 rpm? - There appears to be a huge dip. I assume that the cams are the reason for this. Also, I see that measurements were taken above 7000 rpm!!
Eddie W
PostPosted: Sat Dec 13, 2003 6:23 am    Post subject: Reply with quote
Gearchanges Paddy? Is the peak torque being multiplied by 2nd gear as the standard motor is around the 4000 mark not 2070.
Regards Eddie
Guest - Denmark
PostPosted: Sun Dec 14, 2003 9:10 pm    Post subject: Cool Alfa 33 Reply with quote
Wow - I like your Alfa 33 in race trim. It's really cool.
Nice forum site. Just found it Smile
Come and take a look at my Alfa
http://www.cardomain.com/id/alfa33qv
Greetings
Henrik (DK)
Eddie W
PostPosted: Sun Dec 14, 2003 9:34 pm    Post subject: Reply with quote
With a further look at the chart , it definitely looks as though readings have been taken through the gears which is unusual. The definitive readings would be those in top gear (4th) which would give about 135 lbf of torque which would be more in keeping with the hp figure and still very good. Also this figure occurs at a higher rev range than standard which you would expect from a modded engine. Still it is a wicked bit of gear.
Regards Eddie
Peter D
PostPosted: Mon Dec 15, 2003 9:19 am    Post subject: Protune Road racer Reply with quote
Fine that you sent the printout of the test.
It is done totally wrong, and now we see an explanation.
The first part of the chart is the running in the 1., 2, and 3. gear. It is of no use.
You can only use the part which is in the 4. gear and the speed versus rpm should be put in the computer for this gear (which I suppose it is).
Normally you start up in 1. gear, and then you go directly to 4. gear (or the gear you have decided and put in the computer, speed/rpm). Then you floor the throttle from as low as it can take, 1000 rpm if possible, and then you get the whole powercurve.
On your power curve you can only read out values from above 4.000 rpm and the max torque is at 5.000 rpm, not 2.500 rpm as you believed.
The meassured 135 lb ft is not bad, it corresponds to 184 Nm or 18 kpm and at a more (for a tuned engine) realistic 5.000 rpm.
Peter (DK)
Toad
PostPosted: Tue Dec 16, 2003 3:50 pm    Post subject: Reply with quote
Seen your Car in CCC magazine Smile
I must send you an email with a few question's. I have a Race Sprint and my Friend has a 33 16v. Maybe there are idea's and work on our cars that we could share?
Shift for Brains
Dave_NZ
PostPosted: Fri Dec 26, 2003 5:21 am    Post subject: Reply with quote
looks good. how well does it compare on the track to the suds. what are the wheels that you have on it now. they look very nice.
Dave
Looking for a type 2 33QV in NL
richalfa
PostPosted: Mon Jan 12, 2004 2:46 pm    Post subject: protune 33 Reply with quote
thanks for the explaination for power readings !!!
that sounds correct....
The suds handle much better, in my opinion anyway, ive never driven a 33 as fast round bends as a sud can go,the wheels on the 33 are made by dare and i think they are rs2's ,if thats any help.
mawhawhawhaw!!!
Paul Doc
PostPosted: Tue Jan 13, 2004 1:58 pm    Post subject: Reply with quote
Love the wheels in the "...and leading to this" pictures! Where are those 75 style rear arches from?
richalfa
PostPosted: Thu Jan 15, 2004 12:21 pm    Post subject: Reply with quote
you,ve just said it a 75... Smile
mawhawhawhaw!!!
James Granger (n/l)
PostPosted: Sat Jan 17, 2004 11:57 am    Post subject: Re: alfa 33 1.7 16v pics Reply with quote
Shocked Nice! From which brands are the clover-style rims and the two rear spoilers? What modifications to the 75 arch extensions did you have to make to get them to fit?
James Granger
PostPosted: Sat Jan 17, 2004 11:58 am    Post subject: Re: alfa 33 1.7 16v pics Reply with quote
Sorry, that was me!
richalfa
PostPosted: Mon Jan 19, 2004 2:01 pm    Post subject: Reply with quote
i didnt have to make any modifications to make them fit ,they go straight on
mawhawhawhaw!!!
Serpent
PostPosted: Mon Feb 09, 2004 5:31 pm    Post subject: Reply with quote
Care to post your carb set up here? I am toying around with it too.
richalfa
PostPosted: Fri Feb 20, 2004 4:57 pm    Post subject: Reply with quote
the carbs are set up with 32 mm choke size and are dellorto 40's,
the engine is in bits at the mo ,as it needed a rebuild ,im going for bigger stainless inlet valves and will try out a differnt cam too,
im aiming at getting some more power out of it this time,it seemed there was a good power increase with just the cam's ,and light porting ,with the increased compression ratio i managed 145 bhp and 135lbft of torque...
but the engine was using and old block with old pistons and bearings and was totally standard so its time for some more tinkering and £££
this time i will be building it propper,and will get the correct CR and deck height when i build the bottem end ,ive just had it all reground and some fresh bearings
im going to do some more head work too!
this time im hoping to see 160 bhp with the new cams and head work...
we shall see Very Happy
mawhawhawhaw!!!
Edward
PostPosted: Thu Feb 26, 2004 11:54 pm    Post subject: Reply with quote
Hi there,
You mention in the early part of the text that the original setup was carbs onto a 16V engine - can you explain how you managed to provide / produce a manifold that brought the outlet from the carbs to the inlet of the heads. It seems that some engineering is required here and I am looking for the best way to achieve this without too much reinvention of the wheel...
Thanks,
Edward.
The faster the better.
loui
PostPosted: Fri Feb 27, 2004 9:51 pm    Post subject: Done the carb thing Reply with quote
I'm running a 1.7 16v injection engine on twin Dellortos (DRLA 36?) in a Mk2 1.5 Ti. The unit came from an early 16v 1992 J plate. Just before the front suspension was changed.
Mounting the carbs was the least of my problems.
The mounting plates were the originals from the injection engine.
Everything lined up and the fitting was straight forward.
Only difference was a small v shaped cut section in the plates (cylinder barrell) on the inside, where the injectors went into the cylinder. All closed up properly with the carb gasket set. Don't think it would have cost much to have the v shapes filled with some sort of alloy welding and cleaned up. Planned to do that if it caused a problem
The car has been running with this setup for 2 years (12,000) miles)
Also ran it on twin Webbers for a short period and didn't like the noise.
Main problem was running a fuel pump and regulator to suit the carbs.
The injection fuel pump is not suitable for a carbed engine.
The car suffered fuel starvation at high speed (Motorway+) and during hard prolonged acceleration. Have now fitted a competition pump and regulator. Need to visit a rolling road to have the carbs suitably jetted and the regulator set.
Have wrote down what I did at www.stopthemetalmaggot.co.uk
richalfa
PostPosted: Tue Mar 30, 2004 3:14 pm    Post subject: CARBS ON 16V Reply with quote
I went about it a harder way than the above mentioned ,i went to an aircraft engineering company to get some billet aluminium i got given a large block (for free!)and they even cut it into two pieces suitable for the manifolds,to which i had two holes board in each,at a machine shop (£15) and i basicly fettled them into shape with a drill (best use an air grinder)
,i never managed to achieve its full potential so i cant say what it was like!!
as im now useing an 8v engine of which has proven superior in the money and performance side,and being so much easyer to work on and tune....
mawhawhawhaw!!!
Goto page 1, 2  Next
Page 1 of 2
