BillaBoo Guest
Posted: Mon Jul 18, 2005 11:32 am Post subject: How can i make my gearbox tighter? |
hi!
is there a way to make my gearbox tighter? After some upgrades my car handles beautifully, but the gearbox is so loose Even our 98 nissan almera is tighter! and thats defintely not a sportscar!!
Where can i buy whatever i need to make it tighter? And what do i need to do!?
thanks! |
Posted: Mon Jul 18, 2005 1:52 pm Post subject: |
You could try looking at the gear box linkage under the car. Generally the gearbox on the 33 is loose though. _________________ Fiat Bravo 165 Sport |
Posted: Mon Jul 18, 2005 4:23 pm Post subject: |
Nissan Almera????
Of course the box is tighter on that car. Japanese cars have "precision gearbox selectors".
Italian cars were always famous by doodgy gear selection (Although some were worse than others)
33´s were one of the worses, and by no means you can expect to have an "good as japanese gear selection".
However check your gear linkage. Change the bush on the base of the gearlever, the bushes on the fork, and the bushes that hold the back support to the box & to the body...in some cases it pays off to change the fork itself...
Hope this helps
BillaBoo Guest
Posted: Mon Jul 18, 2005 7:11 pm Post subject: |
| ok, i`ll look into that linkage, maybe change some bushes.. thanks |
