Ken McCarthy Alfa Sprint
Posted: Tue Aug 23, 2005 4:57 am Post subject: Brakes etc |
Hello all.
I am looking for some help to find suppliers of some parts for my car. Some of you will know that my Sprint has the engine/suspension from a 1990 16V, including the ventilated disc brakes. The rear is still Series 1 33 (drums). I want to find rear discs. I know they were fitted to a few front wheel drive Series 3 cars but only a few P4's came here with them. I will need to get the hubs, backplate/caliper mounts, handbrake components as well as the calipers and discs - maybe the stub axle as well if it is different.
I would also like to upgrade the front brakes. I know I can adapt a local disc and caliper but would prefer to use something from the Alfa parts bin if I can. My discs are 239 dia. 4 wheel bolt 284 dia discs with offset dimensions not too different were fitted to the following cars (not available in Australia): 155-2.5i V6 92-97, 155-2.0i 16VTS 95-97, 145/146 1.8i 16VTS 97-00, 145/146 2.0i 16VTS 95-00. If anyone has access to any of these, I have the critical dimensions for my car for comparison, to see if there is a bolt-on fit.
Any information on a limited slip differential, either made for the 33 16V, or able to be adapted from another make/model, would also be appreciated.
If I can confirm the suitability of any of these, the next step is to find a car wrecker (breaker/recycler or whatever the local name is) and make contact with him.
Thanks & regards _________________ Ken McCarthy - 16V Sprint |
Posted: Tue Aug 23, 2005 6:38 am Post subject: |
About the rear axle, I 'd like to add a point. The s3 rear axles had the upper part of the suspension been held from the front portion of the wheel arch in contrast to the previous models (s1 & s2) which the suspension os held from the rear part.
This will probably make a difference fitting the s3 axle to the Sprint.
Good luck, _________________ Thanassis Gritsopoulos
Posted: Tue Aug 23, 2005 7:01 am Post subject: |
Thanassis
Thanks, I know about that. I'm hoping that the rear caliper mounts on a separate backplate that replaces the drum backplate and will go on the existing (Series 1) axle.
Posted: Tue Aug 23, 2005 8:43 am Post subject: |
I have a 1983 Alfasud Sprint with 33 16V front disc brakes and a 33 type 2 rear axle. I also have a series 3 33 16V AND an extra axle. One from a 33 series 3 with ABS (so rear disc brakes on a front wheel driven car) and I also have some P4 rear axles..... al that is missing is time to take the necesarry measurements...
I hope next weekend I will find some time for this. |
Posted: Tue Aug 23, 2005 11:08 pm Post subject: |
Thanks,
Much appreciated. Where are you (city/country). Would you be able to take some photographs and email them to me, particularly of the rear caliper and mounting? _________________ Ken McCarthy - 16V Sprint |
Posted: Wed Aug 24, 2005 7:19 am Post subject: |
I live in The Netherlands.
When I have the time I will take my camera and shoot some pictures! |
Posted: Wed Aug 24, 2005 7:34 am Post subject: |
Thanks again. _________________ Ken McCarthy - 16V Sprint |
Jamesd (guesting) Guest
Posted: Wed Aug 24, 2005 12:46 pm Post subject: Rear Disc Brakes |
Ken,
I have a P4 in Brisbane if you need to have a sticky (no you may not have my brakes). I don't think the rear discs do much for the braking, but the hand brake is less effective and the discs are more expensive than drums.
Rgds
James. |
Posted: Wed Aug 24, 2005 2:58 pm Post subject: |
I think we all agree that discs are better looking than drums?
For me that was more than enough reason to want to get rid of the drums.
The discs don't bolt straight on the backplates for the drums, you will need backplates of a non P4 Alfa 33 with rear disc brakes.... or make them yourselves. In The Netherlands a racer is producing the plates himself. 150 euro's I think. |
Posted: Wed Aug 24, 2005 11:14 pm Post subject: Rear Disc Brakes |
James
Having a look at a P4 would be a great help. The hub and axle will be different of course but I would expect everything else to be the same with respect to the brakes. As you posted as a guest, I can't email you. If you wouldn't mind emailing me, we can set up contact.
Many thanks _________________ Ken McCarthy - 16V Sprint |
Posted: Thu Aug 25, 2005 8:12 pm Post subject: |
Some years ago I was told that the assembly used on the 33 was shared with the Uno Turbo. Although not available in Aus it might be worth a bit more checking.
