Ignition timer relay
Vecchio Alfisti
PostPosted: Mon Jan 09, 2006 9:37 am    Post subject: Ignition timer relay Reply with quote
Hi Very Happy
Does anyone know where the relay that controls the warning lights test on switch on is located? When everything is working, when you switch on the ignition the warning lights all show for about 30 secs and then extinguish. Mine no longer show and I presume that the timer has failed. I want to locate the relay so that I can replace it Smile I cannot seem to locate it on any wiring diagram.
Alfa 33 1.7 QF I think maybe now I m not so sure
