Posted: Fri Feb 10, 2006 10:46 am Post subject: re carbs on 16v |
has anyone got inlet manifolds for a 16v engine so that carbs will fit on them. |
Posted: Fri Feb 10, 2006 3:59 pm Post subject: |
Hi...
There`s not a "bolt on" manifold that you can use...
You have to get hold of 2 intake manifolds from a 16v, and 2 from a 8v carb version....
Have to cut them in half, and weld the bottom part from the 16v to the upper part from the 8v carb intake...
Hope this helps
Rees Cees Alfasud
Posted: Fri Feb 10, 2006 6:38 pm Post subject: |
Bellamachinna wrote: |
Hi...
Hope this helps
P.Camilo |
Posted: Sat Feb 11, 2006 1:25 am Post subject: inlet mainfolds |
thanks  |
Serpent33 Alfa Sprint
Posted: Fri Feb 17, 2006 6:48 pm Post subject: |
Do you mean cut the throttle body off the 16V? _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Posted: Sat Feb 18, 2006 12:24 am Post subject: |
Hi...
Quote: |
Do you mean cut the throttle body off the 16V? |
No... Not the throttle body...
I mean the intakes under the throttle body...
You need to make a hibrid intake if you want to install the carbs on a 16v engine...
Hope it helps
Posted: Sat Feb 18, 2006 4:33 am Post subject: |
I'm curious. So how is the power delivery? As compared to 16V ie. Anyone knows? I actually fabricated the linkage but has not embarked on the project. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Rees Cees Alfasud
Posted: Sat Feb 18, 2006 7:44 am Post subject: |
Serpent33 wrote: |
I'm curious. So how is the power delivery? As compared to 16V ie. Anyone knows? I actually fabricated the linkage but has not embarked on the project. |
about 153 HBP and 200nM Torc for an normal street 16v
about 180 HBP for an Race engine
I have built both |
Posted: Sat Feb 18, 2006 11:59 am Post subject: |
So you get ard 20 bhp just from carbs? |
Posted: Sat Feb 18, 2006 11:22 pm Post subject: |
On my previous series 2 1.5 TI, that i converted to 1.7 16v with carbs, i didn´t notice.
(because i didnt had driven any 16v, with injection at the time)
Now that i own a series 3 16v, i can say that on lower rpm, the carbed version was faster, and more rev happy...
Not much change on top rpm (lack of fuel supply cappacitty by the carburettors ?????)
The series 2 was also lighter, which helped a lot...
The sound was also better... lots of backfires on the overrun...
Posted: Sat Feb 25, 2006 9:54 pm Post subject: 16v |
thanks for the info i have had a 16v 33 and a p4 so will be interesting to see how it comperes when completed. |
Rees Cees Alfasud
Posted: Sat Feb 25, 2006 10:00 pm Post subject: |
something like this
Posted: Sun Feb 26, 2006 11:20 am Post subject: |
This looks high. Any clearance issue? _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Posted: Wed Mar 01, 2006 8:17 am Post subject: |
P.Camilo[/quote]
Hi there. May I ask which distributor coupled your 16V carb conversion? _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Posted: Wed Mar 01, 2006 2:17 pm Post subject: |
I used the 1.7 QV distributtor (series 2)... _________________ All'interno della mia macchina, vi sedete, tenete sopra e CHIUDETE IN SU... |
Posted: Wed Mar 01, 2006 7:04 pm Post subject: |
I'm working on a 16V carb too. So which fuel pump you're using? I'm using carter. And my intended main jet, 160 with enlarged venturis. Since it's a modification, sure will benefit from you guys' experience. btw, gonna start a thread on final drive. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
Frits Alfa Arna
Joined: 27 Nov 2005 Posts: 7 Location: Delft, the Netherlands
Posted: Thu Mar 02, 2006 9:54 pm Post subject: |
Serpent33 wrote: |
This looks high. Any clearance issue? |
It is built in low...
Rees Cees is famous in the Netherlands... so here is a part of its site with pictures _________________ Two type II 33 1.3s SW www.meisenbacher.nl/auto.html
baiones Alfa Sprint
Hi...
Hope it helps
P.Camilo |
NO, NO!!
There's nothing under the throttle bodys.
You have to cut a throttle body, use the down half, and join it to the other piece.
 _________________ Carpe diem!!
Baiones
ALFA ROMEO 33 1.5 QV
ALFA ROMEO 33 1.7 QV
ALFA ROMEO 33 s16 QV
ALFA ROMEO Sprint 1.3
ALFA ROMEO 156 SW "Train Edition" ( it's a JTD... ) |
KitCarLasse Guest
Posted: Mon Mar 06, 2006 6:59 pm Post subject: CNC bolt on 16v / karb manifols for sale |
Hi im a guy from Denmark wich builds kitcar's on the VW type 1 chassis and uses Alfa Romeo boxer engines....the adapters for the vw transaxel to fit the alfa boxer is a part we ourself produce.....
Last year building my kitcar we ran into a problem - all racers used them but had never been produced in series prof... Intake manifol's for the 1,7 16v engine to adapt weber / dellorto 40mm karburators !!!!!!
I have seen many pour intake manifols wich we could call homemade
So my buddy Rolf and I desided to manifactor aset of super smooth super flow manifols - bolt on easy - made in one piece alu......
The price for a set of two manifol's are 3300 DK kr or about 472 euro !
Get more info write to me : kitcarlasse@yahoo.dk or +45 23 310 310
3D picture from the cnc-machine is possible to mail to you ! |
KitCarLasse Alfa Arna
Joined: 06 Mar 2006 Posts: 24 Location: Copenhagen, Denmark
Posted: Mon Mar 06, 2006 7:13 pm Post subject: Picturelink+More info of CNC manifol for 16v / karb adaption |
More info... our manifol is lower than them you kan make off old throttlebodys + lighter weight..... + much better flow and no blind ends from old injectors
SO YES THERE IS A BOLT ON MANIFOL FOR KARB/16V SOLUTION
Link to danish website with picture from our CNC machine :
http://vwnettet.dk/modules.php?name=Forums&file=viewtopic&t=16041&highlight=16v
As you can see on the picture is our manifol superlow, the vacum fitting are build into the socket, the optional hole for brake vacum + sensors are ready for fit if you need them, finally the cooling water comes through an stainless steel pipe fitted into the alu manifol with 40 tons off weight !
This IS serious
Plastic is fantastic
KitCarLasse
+45 23 310 310
1 sæt special fremstillet manifols til 2 stk dobbelte 40mm weber / DellOrto'er til brug for Alfa 16v boxer motoren der ellers kun er lavet med sprøjt !!! Dette giver ca min. 160-163 hk...
1 sæt pol alu ubrugt manifols bolt on - 3300 kr
Rigtigt fint til feks en buggy / kitcar sammen med en Alfa Adapter
1 adapter sæt komplet bolt on 5000 kr
: 26.07 KB
: Billedet er set 146 gange
Sidst rette af kitcarlasse den Ons Mar 09, 2005 5:03 am, rettet 1 gang
Rees Cees Alfasud
Posted: Mon Mar 06, 2006 7:16 pm Post subject: Re: CNC bolt on 16v / karb manifols for sale |
KitCarLasse wrote: |
wow that´s a lot of money. my were also proff made and they cost me:
2 intakes off an 16v. some hours flowing and 30 euro for welding.
My engine with 40mm dell orto´s is a pro engine and gives more than 180 Hbp |
Rees Cees Alfasud
Posted: Mon Mar 06, 2006 7:17 pm Post subject: Re: More info of CNC manifol for 16v / karb adaption |
How to put in a picture off our proud work ???
KitCarLasse
+45 23 310 310 |
lower means less torc! and the mixture off air and petrol is warmer.
Posted: Mon Mar 06, 2006 7:29 pm Post subject: |
The low manifol is made like this to fit under any hood.... however the all can be fitted with a spacer to make the hight that you want.... We further can offer an special made set for you to fit a 36mm karb og maybe a 48mm ? If you order a set just tell how higt you want the intake manifol from the engine surface and up to the karburator surface.... your wich is my comand Remember this is NOT an glue together part - THIS is made especially for you in one piece solid alu........  |
Rees Cees Alfasud
Posted: Mon Mar 06, 2006 7:51 pm Post subject: |
Sorry i am not intersted in buing one of your intakes mine are working fine an fit alsow under the hood of my plastic 33
Why are you using alfa boxers in a kitcar? Subarau boxers are better, have standard more power and are better built (sorry alfa frends) |
Posted: Mon Mar 06, 2006 8:39 pm Post subject: |
Cause off the pour conditions we have here in Demark regards building cars ourself.... the Alfa boxer is the only one wich are OK by the carinspection to get on the street.....
We soon will make an adapter for mounting bigger brakes at a 33.... anybody interested ?
Plastic is fantastic...... my kitcar weights total 620 kg and runs with a 33 1,7 16v engine fittede with two 40mm DellOrto karbs.... the tires are 205/50/15 and rear 345/35/15.... lightweight and good grip
kitcarlasse |
