brakes?
markgp4
PostPosted: Tue Feb 28, 2006 2:31 pm    Post subject: brakes? Reply with quote
Can anyone suggest why i can feel the engine thro the brake pedal when i press it? its especially obvious on tickover...
could it be a worn engine mount??
thanks
make it go faster Smile
sportston
PostPosted: Sat Apr 08, 2006 7:45 pm    Post subject: possibly Reply with quote
Outside chance of it being worn engine mount. But possibly more likely to be something else touching/leaning against the brake mechanism under the bonnet somewhere. U may need to get right in there and identify what and where though. DO NOT IGNORE THIS PROBLEM! IT COULD BE DANGEROUS!
It could be a brake line chafing, for example, and lead to brake failure. It could be speedo cable or something similar incorrectly routed and be harmless. But then again..... Hope u find it.
markgp4
PostPosted: Sat Apr 08, 2006 8:15 pm    Post subject: Reply with quote
thanks for reply buddy,
the car is in peices at moment
(see here http://www.alfa-pages.co.uk/viewtopic.php?t=2603
and it does need new brake pipes right thro front and back due to corrosion but i will take care when i put it all back together...
