Posted: Mon Aug 28, 2006 7:08 pm Post subject: advice on 16v indicator moulding |
I have removed all the black plastic mouldings along both sides of the car and will get the black unpainted parts of the front and rear bumpers painted to match. Anyone got any ideas on how to affix the side repeaters?
There are 2 holes in the wing with a 75mm gap between the holes that holds the moulding in place. I have taken out the hard plastic from within the rubber moulding and tried just using that, but it doesnt look good. I have seen a blue late type 33 with the same thing done but cant see how there held in. Any suggestions? _________________ x2 33 16v
stedee Alfa 33
Posted: Mon Aug 28, 2006 7:24 pm Post subject: |
glue it in or those strong sticky pads. i did a similar thing to a black ie i had .my car was black and the plastic mouldings were that typical charcoal grey. i filler primered all the plastic mouldings while on the car and resprayed it in 2 pack paint. it came out very good i have to admit it looked like it was a special edition _________________ brum brum |
Posted: Mon Aug 28, 2006 10:05 pm Post subject: |
"No more nails".
Posted: Tue Aug 29, 2006 9:22 am Post subject: |
thanks for the suggestions, I have seen a red late type 33 with the black rubber mouldings colour coded to match, but it didnt look good In my oppinion, i think they look much better with nothing there at all, thats comming from a previous mk1 owner
No more nails my mate tried to glue the bottom of his trainers with that stuff, no names mentioned "pat" and it flew everywhere when we played football. I would like to be able to remove them, so maybe velcro  _________________ x2 33 16v
Rich B Alfa 33
Posted: Tue Aug 29, 2006 11:50 am Post subject: |
you could try getting some side repeaters from a lower spec car like a 1.3. These didn't have the side mouldings and had a slightly different arrangement for the side repeaters and should come with fresh adhesive pads to fix them on. I'm sure if you asked Bobbber nicely he could look up the part number on E-per |
stedee Alfa 33
Posted: Tue Aug 29, 2006 5:13 pm Post subject: |
you could use a glue gun that usual separates quite nicely and cleanly if you want to take them off _________________ brum brum |
Posted: Mon Sep 04, 2006 4:44 pm Post subject: |
Hey folks. I'm confused a bit here. In the eBay listing he shows the chassis number which ePer then translates into a Series III car with a 1.3 engine.
The ePer 'greys' out the parts which are not applicable to this car.
Therefore it's a item 10 - base? But if that's the case.... where's the huge lumpy one for the "trimmed/railed" 33's???
gritop - you have these on your car right??? Can you help!?
Posted: Mon Sep 04, 2006 4:54 pm Post subject: |
I'm willing to bet it is part 10 - and that they have the parts in the picture back to front.
So the part 10 should be the small surround - and 11 should be the large 'rail' type fitting.
You can see from the "V" numbers in the listing for 10 & 11 that you can have one or the other.
So I reckon it's a 60526031/2 required. Also, the cost of one part is £13 and the other is £1.65! So I'm pretty confident about this one.
AND another thing.... there are no clear side repeaters in the catalogue - only amber. Although I'm pretty sure I saw clear ones on Lee16V's car.... Lee?
Posted: Mon Sep 04, 2006 5:00 pm Post subject: |
I have asked Richard, the parts guy at my local afla dealer about this. I also gave him a links to ebay and this thread.
bobber, i sent you some more pics It is the hard plastic moulding that was inside the whole strip moulding. However it broke and doesnt look good when fitted.
I bet it is as follows, part 10 the whole plastic moulding, part 11 the indicator _________________ x2 33 16v
Posted: Mon Sep 04, 2006 5:18 pm Post subject: |
Nope the indicator is on a separate section of the catalogue
You can have 10 OR 11 - not both. So I reckon the moulding on the eBay listing is part 10.
Posted: Mon Sep 04, 2006 10:29 pm Post subject: |
Hello guys,
Just seen the topic here. Bob, no my car does not have the trimmed plastics in the doors.
It appears that the drawings are little confusing here and cannot clearly distinguish the difference between the base of the repeater indicator among the base and sport models.
The 16V model has a large base where it actually covers the strip in the front fender in full length (part 11). Regular models have just the base around the repeater just like the photo below which I'm pretty sure it is part 10.
The side repeater is under product code 60538358 and it is in the signalling devices section of ePer.
Bottomline is that ePer DOES have errors and parts description that may confuse us. However the dealers know these pitfalls and can correct you.
Posted: Mon Sep 04, 2006 11:09 pm Post subject: |
Not the kinda guy to say "i told you so"....but....  _________________ Fiat Bravo 165 Sport |
Posted: Tue Sep 05, 2006 4:48 pm Post subject: |
I did look into getting clear ones but they're not available
Bob...... mine are black/ smoked handmade jobbies  |
Posted: Tue Sep 05, 2006 9:23 pm Post subject: |
thank you very much guys, bobbber, you can say, "i told you so", i dont mind So i need part 10 60538358, i will order it tomorrow. Sorry i took so long replying, not been home and my frind has dial up
Thanks again. I might see if i can get the part colour coded (sprayed) before i fit it.
Did they actually make clear ones?? _________________ x2 33 16v
Posted: Wed Sep 06, 2006 12:08 pm Post subject: |
I just spoke to richard and he is sure that part number is the indicator, he cant see the pics so i am emailing them to him now. I will call him in 1/2 an hour.  _________________ x2 33 16v
Posted: Wed Sep 06, 2006 8:38 pm Post subject: |
Posted: Wed Sep 06, 2006 8:41 pm Post subject: |
Al! This is driving me bonkers!
If I get you a pair you'll pay me for them yeah? £2 each plus P&P.... deal?
And Lee - you sound like your making Cuban cigars!
Posted: Thu Sep 07, 2006 1:21 am Post subject: |
hold the fort bobbber, i spoke to richard and he has orderd them. If they are incorrect when they come, can i take you up on your offer? _________________ x2 33 16v
Posted: Thu Sep 07, 2006 4:06 pm Post subject: |
Quote: |
And Lee - you sound like your making Cuban cigars! |
Lol  |
Posted: Thu Sep 07, 2006 10:05 pm Post subject: |
Al,
No problem.... glad to be of help if you want me to.
(transaction held!!!!)
Posted: Thu Sep 14, 2006 10:10 am Post subject: |
Wahoo, i finaly took possesion of 1 side repeater indicator holder moulding, the other is on back order (from Itialy). Try saying that when your drunk, it looks like the picture gristop posted, its off a 1.5 ie model. Im not liking the colour, so i will get colour coded.
Thanks agains peeps. _________________ x2 33 16v
