tempra2 Alfasud
Posted: Fri Mar 30, 2007 8:15 pm Post subject: The Eagle has Landed - My New P4: Pics |
Thanks for all the help and advice, here's some pics the PO took whch he's kindly let me post:
*Piccys*
55K, FSH and it's as good as it looks!  |
Posted: Fri Mar 30, 2007 9:03 pm Post subject: |
She's a Beauty
Is that metalic dark grey dark beast behind also yours? _________________ Tino Vatavuk
tempra2 Alfasud
Posted: Fri Mar 30, 2007 9:21 pm Post subject: |
Hi Tino!
Sadly not, that's the previous owners 3.2 facelift. He also owns an SZ - top bloke (Obviously: the cars say it all!)  |
Posted: Mon Apr 02, 2007 7:30 am Post subject: |
Minter!
Enjoy
33 16v '93
145 2.0 Clover '97 (The wifes - sort of!) _________________ If it aint broke, fiddle with it until it is!
tempra2 Alfasud
Posted: Mon Apr 02, 2007 10:38 am Post subject: |
Cheers John!
This is what I spend yesterday doing: Service items
Only had 5 hours, but managed to:
- Replace the cracked coolant hose from the T’stat to the left side intake.
- Replaced all the other hoses to the t’stat as a precaution and the T’stat itself.
- PAS and Alternator Belts
- Flush and change the coolant
- Change the Engine Oil and filter
- Change the Diff Oil
- Change the Air Filter
- Change the dissy cap and rotor arm
Still need to:
- Change the gearbox oil (The oil from the diff was as new, so I’ve got high hopes that the gearbox oil will be the same).
- Change the fuel filter
- Change the PAS fluid
- Change the plugs
- Take some photos of the goodridge hoses for Tino(!)
- Do the brakes: New lines, discs, fluid and pads – still waiting for the front discs! |
Posted: Mon Apr 02, 2007 8:14 pm Post subject: |
I'm assuming you've had a 33 before?
If not, the plugs are a right old fiddle the first time, mostly working by feel with the plug spanner from toolkit. It looks like your p4 has been cherished, so hopefully the plugs will have been previously 'coppaslipped' which helps alot. Take out the airbox, and place a good book or magazine on the intake manifold!
tempra2 Alfasud
Posted: Mon Apr 02, 2007 9:08 pm Post subject: |
Thanks John; yes had a 16v before, but it was cat so the plugs were platinum so I never had to change them.
Got the tools in the kit fortunately, but yes it looks like a PITA!
My specialist advised against the cost of platinum plugs saying that the 16v's always flood and then won't start and the only way to get them going again is to change the plugs. Ever heard of this? My old car was always fine  |
Posted: Tue Apr 03, 2007 8:56 am Post subject: |
Never known my 64,000miler 16v (with cat) to flood in the 6 years i've had it.
Mine has the platinum plugs, which i've had out a couple of times. I've actually got a brand new set of platinums i got cheap on ebay, which i may whack in when i next service the car if i'm feeling very keen.
Have resprayed nsf door and spoiler in the last 10 days, waiting on brand new marrelli new nsf electric window reg assy (ebay!), then hoping for some time to put in new headlights, new front shocks and strut bearings.
Spent all free time last weekend servicing and tidying the wifes 'new' 145.
Trying to get to Spring Alfa Day for the morning, hope to see you and the p4 there!
Posted: Tue Apr 03, 2007 3:06 pm Post subject: |
| Quote: |
Mine does this IF i use the Golden Lodge plugs. It looks like yours, but is the front wheel drive version.
If i use the Golden lodge plugs, especially in damp weather, the car as a tendancy to flood, and the only way to start the car again, is to remove the plugs and clean them....
I switched to NGK plugs, because eventualy they also flood, but the car starts on 3 cylinders, and after warming up, it "switches" the "dead cylinder into life...
I`ve tried everything, to prevent this from hapening (from new injectors, new fuel damper, new plug leads, new plugs, new distributor...The list is long) but sometimes (in damp weather) he fires on 3 cylinders..
When someone gets the cure for this i will be happy to know...
P.Camilo
P.S.-By the way your car looks Awesome _________________ All'interno della mia macchina, vi sedete, tenete sopra e CHIUDETE IN SU... |
Posted: Tue Apr 03, 2007 4:38 pm Post subject: |
Camilo,
friend of mine owned FWD noncat 16v with similar but worse problems, he would start engine on two cyls, fuel consumption was from 15-30% more....
He replaced fair bit of things he could replace/plugs,sensors... and check out... after he sold it new owner changed wiring and voila new car. _________________ Tino Vatavuk
tempra2 Alfasud
Posted: Wed Apr 04, 2007 11:24 am Post subject: |
Oh Good - I bought NGK's so hopefully it'll at least go in the morning!
FYI: I asked the specialist if there was anything I can do to prevent the flooding on startup - he said never touch the accelerator on startup helps - don't know if it's true though. |
Posted: Wed Apr 04, 2007 3:38 pm Post subject: |
| Quote: |
What wiring did he change???
The wiring for the ECU, or the "normal" wiring???
Or did he changed EVERYTHING????
| Quote: |
Yes this is true... But if your car has some vacuum pipe disconnected (like mine had) it simply doesnt start at all, if you dont give it a kick in the pedal...(this problem is already solved in mine)
daniiodtb Alfa Arna
Joined: 05 Apr 2007 Posts: 1 Location: Poland(zyrardów)
Posted: Thu Apr 05, 2007 11:32 am Post subject: |
Real beauty and great seats Recaro This is my first post on this page and I am happy I could write on your site.  |
Posted: Thu Apr 05, 2007 3:09 pm Post subject: |
Welcome to Alfa Pages!
A new thread telling us a bit about yourself and some photos of your 33 would be great!
Thanks for joining!
paddy granger Alfa Sprint
Posted: Mon Apr 16, 2007 12:54 pm Post subject: |
Nice one! How I miss my 33...
Looks like it has had a good history of owners, well done for finding this one. |
twinspark Alfa Arna
Joined: 24 Apr 2007 Posts: 22 Location: Fife, Scotland
Posted: Tue Apr 24, 2007 2:08 pm Post subject: |
Thats very nice mate!
Not alot of difference externally to my Cloverleaf, headlight washers and the different alloys, are they 15's?
....... I want to get badges on the side of mine now after seeing yours!  _________________ P17SUT - tourismo internazionale |
tempra2 Alfasud
Posted: Wed Apr 25, 2007 9:41 am Post subject: |
Cheers Twinspark - they the boggo 14" P4 alloys, which I'm quite happy with.
Don't think you can get the small cloverleaf stickers anymore, just the right big ones  |
twinspark Alfa Arna
Posted: Wed Apr 25, 2007 10:44 am Post subject: |
| tempra2 wrote: |
Maybe should just leave my standard 14's on then......unless I can find a nice set of 155 15" in the split rim style!
I've found plenty of the large side stickers on ebay, but abarth-badges have small proper metal ones for £21 each!.......think i'll just get the big stickers for £3.  _________________ P17SUT - tourismo internazionale |
