Eddie_W Alfasud
Posted: Thu May 15, 2008 10:20 pm Post subject: Brake pads S2 vsS3 |
Hi guys, just a quick question, does anyone know if the S2and S3 front calipers are the same? Chap here in NZ selling some performance pads at a good price but only lists them as '90 onwards, 8v, 16v and AWD (read P4). Need to move on them quite quickly so any help asap would be appreciated.
Posted: Fri May 16, 2008 5:14 pm Post subject: |
As long as your front discs are vented and the pads are for the bendix caliper, then the pads should fit. Im only aware that Alfa only fitted 2 types of calipers to the 33 series 2 and as I said before and Im sure that the 16v and p4 front brake calipers are the same. _________________ PHAT 33 |
Eddie_W Alfasud
Posted: Fri May 16, 2008 9:55 pm Post subject: |
Thanks for that Iain. Discs are vented but I'm not sure what breed the calipers are. I will check. This I'm looking at as an interim measure until I upgrade to bigger rotors and hopefully 4pots.
Posted: Sun May 18, 2008 9:39 pm Post subject: |
Ive just acquired some hi spec 4 pot race calipers with 300mm discs, fitting them next weekend so i will let you know how good or not they are . _________________ PHAT 33 |
