Posted: Thu May 22, 2008 4:09 pm Post subject: Catalytic converter |
Hi all,
Looks like my 33 is under midlife crisis. Within the past 2 months it has decided to keep me on the go; fuel tank and radiator leaking, battery going flat (just 4 years old though), braking system almost having replaced everything and still the car pulls under braking and just today I discovered that the exchaust gases are way too high
Under the annual exhaust gases inspection, the 33 isn't eligible to renew the emmissions certificate as CO is > 2.0 (limit is 0.2) and HC almost hit the legal limits ~120 ppm with tendency to rise.
I had the L sensor and cat replaced in January 2006 which makes it almost 2.5 years ago. The replacement L sensor is a Bosch unit and the cat under the Walker brand.
Any ideas what the problem is here? Should I just go and get a new AmeriCat or replace the L sensor as a first step? The test machine was showing the L sensor rapidly responding to the engine revs ; from lean to rich right away as the throttle was opening.
Any help from you guys before I am after a crisis myself...
Posted: Fri May 23, 2008 12:32 pm Post subject: |
First thing to try is a voltmeter over the lambda probe and check that it is responding (the voltage should vary, steady voltage means the sensor is dead).
Posted: Fri May 23, 2008 5:13 pm Post subject: |
Hi all,
The L sensor is fine. The gas analyser showed a rapid change in the mixture (lean or rich) as the revs were changing from low to high.
So today, I got a new catalytic converter made by AmeriCat and the emmissions are now at their normal level
I got a new certificate for the next year and figures are :
CO: 0.02
HC: 17 ppm
All within legal limits and on the low side of the limits
Now waiting for the next problem to arise
Thanks all _________________ Thanassis Gritsopoulos
Posted: Fri May 23, 2008 6:25 pm Post subject: |
put your old cat back on and only put it on for the next mot, as long as there are no road side checks done in your area. _________________ x2 33 16v
mt Alfa Sprint
Posted: Sun May 25, 2008 1:27 pm Post subject: |
Good you got it sorted Quite scary that the roadside tests are common place, they'd have a field day over here! Hmm, could relieve congestion slightly though... |
Posted: Sat Jan 03, 2009 7:19 pm Post subject: |
Although this thread is a little old the catalyst I had bought new in May gave up the ghost not a long ago.
CO and HC were skyrocketing! Fortunately the shop replaced the cat under warranty although the owner was "confident" that the exhaust had a leak somewhere and oxygen was the reason to "burn" the catalyst.
No matter how hard he tried he couldnt find a leak plus the fact that each bolt and stud of the exhaust were fully tight (even though he wanted a loose bolt somewhere )
Call it luck I found a brand new original AR catalyst for 330 € in an exhaust shop which was a pure bargain. It was a shame to have it escape so i bought it and whenever the Americat fails it will install the original one right away.
Posted: Sun Jan 04, 2009 12:16 pm Post subject: |
Now you have that warm secure feeling of having a genuine spare cat, the pattern one will last forever now
