Posted: Sat Jan 31, 2009 10:20 pm Post subject: T2 Tester |
Hey guys,
I am fitting a T2 Tester but thought i would make it permanent like the 164.
I was thinking of putting the LED in the spare light bulb hole in the dash, where the 4x4/choke light is.
Where should i put the push button, on one of the spare switches by the fog light switches, or drill a hole in the bottom of the instrument cluster surround?
What do you think? _________________ x2 33 16v
Posted: Wed Feb 18, 2009 10:32 pm Post subject: |
Here is the start to the installation guide.
Content of BOBBBER'S kit
30" of wire
10" of heat shrink
4 spade connectors
1 T2 connector
1 LED
1 Resistor
1 Huge push to contact switch
I will see if i can do 2 guides, one for the temporary in engine bay and the other permanent one fixed into the dash.
For the permanent one, please refer to bobbbers guide on how to replace dash bulbs, on how to remove the dash.
I am a bit annoyed that my dials came out wrong as i could have fitted them at the same time, so i might wait until they arrive or just take it apart all again when they do arrive. _________________ x2 33 16v
