Posted: Sat Jul 18, 2009 8:29 pm Post subject: |
Worn out ignition key? _________________ PHAT 33 |
Dr A. 33 1.5IE Alfa Sprint
Posted: Sun Jul 19, 2009 12:08 pm Post subject: |
What about the earths? Are they clean? _________________ 1994 Alfa 33 1.5 IE Cat. 220.000Kms and still going strong!!! (Από την Αθήνα και τώρα στην Λευκωσία) |
Posted: Sun Jul 19, 2009 7:55 pm Post subject: |
Dr 33
well done, you are correct, the earth leads on the engine block clears the problem when wiggled.
Now what prize do you get??? _________________ x2 33 16v
Posted: Mon Jul 20, 2009 11:18 am Post subject: |
Now you don’t think I was secretly asking for help and then pretending that I knew what the problem was are you, shame on you.
The weird thing it that last year when this happened I took off all the earthing wires and sanded them down, I sanded them down so mush that I took the top coating off and they are copper. When I looked at them last week I noticed that the L plate had rusted and the multi point wires have tarnished. I would have thought that when I sanded down the whole lot and then tightened them up that the contact point would not tarnish or corrode as it’s not exposed. I guess I was wrong, should I coat them in grease thit time? _________________ x2 33 16v
Posted: Mon Jul 20, 2009 12:49 pm Post subject: |
Grease will do it Al or a good dollop of Vaseline is good if you ,ahem, have it to hand. |
Posted: Mon Jul 20, 2009 3:44 pm Post subject: |
BigAl wrote: |
oi oi lol
i have some molly and wheel bearing grease to hand lol. |
Now thats just plain filth al!!! _________________ PHAT 33 |
Posted: Mon Jul 20, 2009 5:21 pm Post subject: |
BigAl wrote: |
oi oi lol
Who's Molly, will she be coming to the next meet? _________________ If it aint broke, fiddle with it until it is!
Boxerbeat Alfa Arna
Posted: Mon Jul 20, 2009 11:53 pm Post subject: |
A little off topic but it is starter motor related. Years ago on a Sud my starter motor packed up, I had a spare in the shed so swapped it out and all was good for a couple of days and than BAM this one packed up also. Two starter motors in the space of a week.....
Any guesses to what caused the problem |
Eddie_W Alfasud
Posted: Tue Jul 21, 2009 10:51 am Post subject: |
I've had starting probs for ages with the motor turning over too slow if the battery was less than full charge. I buggered around with all sorts of things and in the end, in desperation, I ripped the +tive and -tive main battery leads out of one of my donors and doubled up with the originals. Instant transformation. Without the voltage drop due to resistance in the original leads it spins over like a jappa Just a suggestion.
Posted: Tue Jul 21, 2009 5:59 pm Post subject: |
Well i had the problem again today, i thought, ill just wiggle the wires, but oh no, nothing got her to start, i even borrowed someone to turn the key whilst i gently tapped on the solenoid.
I used a spare piece of wire and connected the + on the battery to the exciter wire on the starter motor, off it went, so deffo not the starter.
I am now scratching my head again as it has worked since.
Maybe i will remove the earthing wires and check the resistance on it then eddie. _________________ x2 33 16v
Boxerbeat Alfa Arna
Posted: Wed Jul 22, 2009 1:07 am Post subject: |
Not sure if your wiring loom is the same as on my base model but if it is have you checked the multipin plugs that connect the engine bay loom to the car.
They are located in the battery bulkhead area on the drivers side beside the heater unit, at least on mine thats where they are. I was surprised when I saw these as suds and Sprints never had them. They do look a potential culprit for corrosion and bad connection issues. Might be worth unplugging them, cleaning all the connections applying some WD 40 and reconnect......could be the problem. |
Posted: Wed Jul 22, 2009 11:16 am Post subject: |
I think those are on the ser 2. Mine has wires going directly from the battery terminals to the engine block earth and to the positive on the starter motor.
I was confident that it was the earth on the engine block the other week because wiggling them cured the non starting, now it doesnt, go figure. _________________ x2 33 16v
Boxerbeat Alfa Arna
Posted: Wed Jul 22, 2009 11:41 am Post subject: |
Mine is a series 3. Although the main power supply leads for the starter are diresct from the battery the wire that activates it from the key will be passing trough the main loom and through these connectors. |
Posted: Wed Jul 22, 2009 1:38 pm Post subject: |
my bad, i thought you were refering to the earthing points that are on the ser 1 and 2, a load of earthing points in a circle, let me put my reading specs on lol.
I did remove the block connectors and wiggle all the wires before, again no difference.
When the problem happens you can see the battery light dim when I turn the ignition key to start the car. _________________ x2 33 16v
Posted: Wed Jul 22, 2009 5:28 pm Post subject: |
Sounds like a short, or severe battery drainage Al. _________________ PHAT 33 |
Posted: Wed Jul 22, 2009 5:46 pm Post subject: |
I believe the battery light dimming is normal, as it happens when there is no problem, looks like power is going to where it should but starter motor doesn't activate.
Its been ok since i last used direct connection from + on battery to exciter wire. _________________ x2 33 16v
Eddie_W Alfasud
Posted: Thu Jul 23, 2009 7:55 am Post subject: |
Battery light dimming is not normal . It indicates a very suspect battery or a major resistence somewhere. I would suggest using jumper leads from +tive to starter and _tive to a good connection on the motor. If it starts instantly it is the main leads at fault.
Posted: Thu Jul 23, 2009 10:39 pm Post subject: |
hmmmm, I do the + to exciter wire when I cant get it started and it starts no problem.
I had a good wiggle with all the wires today when it wouldn’t start after starting fine first thing. I don’t know if I should temp fate and say it was the exciter wire, I guess I didn’t wiggle it enough.
You wait I’ll be here next week saying it wont start again as I have already done all this in the past, but this time I’m not stripping the starter motor again!!! _________________ x2 33 16v
Posted: Sat Nov 07, 2009 7:19 pm Post subject: |
Well i am back with the same problem.
Dr A. 33 1.5IE wrote: |
If you have already tried to connect a wire from the battery straight to the starter motor and it started then it is not the motor at fault.
Better check the ignition module. It might need replacement (about 30 Euros for a used one) but also make sure thay the wiring that connects the ignition module with the main wiring loom (under the steering wheel) has all in place.
When you are having the problem just wiggle a bit the ignition wires. Maybe one of them is broken.
Best of luck |
john 33_16v wrote: |
I'd just do the mod. It's very straightforward, then problem solved and no hacking your dash to bits- although a start button might be cool.
You just need some suitable cable, relay (mine was an old spotlight one i had kicking about), a few conectors, and a fusable link near to the battery terminal.
John |
If it is the ignition module, would doing the sanders mod not work?
No wiggling of any wires cures it now, i have to use + from battery to exciter wire. _________________ x2 33 16v
