brake fluid leak
Goto page 1, 2  Next
PostPosted: Tue Aug 18, 2009 11:07 pm    Post subject: brake fluid leak Reply with quote
Hey guys,
I just noticed a puddle of brake fluid upon my return today.
It is not coming from the brake fluid reservoir, or the front brake. It is of centre, towards the drivers side, roughly inline with the rear of the wishbone.
Anyone got any ideas, it just seems a weird place?
Alan.
PostPosted: Wed Aug 19, 2009 2:48 pm    Post subject: Reply with quote
Clutch slave leaking? Dripping on gearbox and then exiting where you say?
PostPosted: Wed Aug 19, 2009 2:53 pm    Post subject: Reply with quote
ahhhh, thanks, heres hoping.
Oggie
PostPosted: Wed Aug 19, 2009 5:34 pm    Post subject: Reply with quote
hopefully someone elses car al, not the alfa!
PHAT 33
PostPosted: Wed Aug 19, 2009 5:47 pm    Post subject: Reply with quote
That would be passenger side.
PostPosted: Wed Aug 19, 2009 6:02 pm    Post subject: Reply with quote
ITS MY PARKING SPACE!!! lol I have been loosing brake fluid of late, as i had to top up the other day
I looked and there are no signs of leakage by the clutch slave cylinder, which paul hinted at, is on the other side, but i was hoping for something simple.
I will be doing a fuel pressure test tomorrow so might get to investigate further.
Was hoping it was a comon thing but oh noooo!!!
PostPosted: Wed Aug 19, 2009 11:01 pm    Post subject: Reply with quote
Well there are only a few places it could be leaking from. From the reservoir to the pipes, there's only so much to check.
PostPosted: Thu Aug 20, 2009 12:01 am    Post subject: Reply with quote
thats what i thought,
there are no leaks around the res, as i said Smile, there are no leaks by the clutch slave cylinder, its got me stumped, until i can get under the car.
PostPosted: Thu Aug 20, 2009 9:38 am    Post subject: Reply with quote
Isn't there a brake pipe union somewhere near where you're talking about?
PostPosted: Thu Aug 20, 2009 10:04 am    Post subject: Reply with quote
Clutch master cylinder?
The one on my dad's minari failed recently- didn't leak though
PostPosted: Thu Aug 20, 2009 12:57 pm    Post subject: Reply with quote
I cant remember, waaaaa, thought id ask before looking around.
john 33_16v wrote:
Is that combined with the brake master cylinder?
PostPosted: Thu Aug 20, 2009 2:54 pm    Post subject: Reply with quote
[quote="BigAl] Is that combined with the brake master cylinder?[/quote]
Nope, it's separate.
Fed from same resovoir though.
PostPosted: Thu Aug 20, 2009 6:29 pm    Post subject: Reply with quote
I dont know what I'm looking for, waaaaaaaaa.I didn't get a chance to investigate further as i was testing the fuel pressure regulator
33bits
PostPosted: Fri Aug 21, 2009 10:24 pm    Post subject: Reply with quote
How do all these faults find your car Al? you must be a magnet to them. If it is the clutch master then its not the easiest item to change, then again some clutch slaves can give a bit of trouble too. Have you noticed any spongy feeling in the pedal Al? or a diff feel to the clutch pedal?
155 sportpack
PostPosted: Sat Aug 22, 2009 12:21 pm    Post subject: Reply with quote
I guess I'm lucky,,,, not!!
No and no, I am running out of brake fluid fast though..... Might have to go to HellFrauds to get some more.
PostPosted: Wed Sep 16, 2009 8:34 pm    Post subject: Reply with quote
I have let the break fluid drain and left it untouched. It stops just below the clutch slave cylinder feed pipe and has not gone any further. The break pedal is still firm, so you guys must be right in saying that it is the clutch master cylinder.
What now, what is involded in replacing one of these?
PostPosted: Wed Sep 16, 2009 8:47 pm    Post subject: Reply with quote
bobbber said that than has just added this
http://www.alfa-restoration.co.uk/clutchmaster/index.html
to the restoration pages.
OMG, i am not restoring, just replacing, can i just remove the clutch master cylinder without removing everything else?
Where and how has my break fluid gone to get to the underneath of the car?
PostPosted: Wed Sep 16, 2009 10:15 pm    Post subject: Reply with quote
most of the time the culprit is the clutch slave cylinder. Follow the pipe from the master cylinder, you'll find the slave. At the end of the slave cylinder there's a rubber gaiter. Press the gaiter between your fingers, if it's wet then you've found the problem.
Master and slave cylinders can be replaced without too much trouble.
Master cylinder : prevent the bolts from turning at the cylinder side and slacken the nuts from the footwell compartment. Disconnect hydraulic pipe at the master cylinder. Disconnect linkage from pedal and it's done.
Slave cylinder : gain acces to the cylinder by removing whatever rubber hoses are in the vincinity. Disconnect hydraulic pipe at the master cylinder. Remove circlip (not easy - good circlips pliers required). Remove cylinder, sometimes stuck in the block, use WD40 and pry it out. Grease mating surfaces when installing new one to prevent it from seizing in the block.
You'll need to bleed the system at the end.
zp
PostPosted: Thu Sep 17, 2009 9:48 am    Post subject: Reply with quote
Thanks ZP, i have done a slave cylinder before and agree the circlip is fun, once one of these came loose and the slave cylinder popped out.
I have checked the slave cylinder already, the fluid leak comes from the drivers footwell area RHD
PostPosted: Wed Sep 23, 2009 11:44 am    Post subject: Reply with quote
I had to move the car yesterday and blead the clutch, by myself, had to remove the plenum chamber to do it, what a PITA. I am guesing that this has never been done before as it was black and after several pumps of the clutch pedal, still came out black. How many pedal pumps should it take to clear through, i did about 9 and stopped, should it clear and should i keep going till it clears?
I should be able to investigate further now. Does anyone have a spare Clutch master cylinder if it turns out to be the culprit?
PostPosted: Wed Sep 23, 2009 2:30 pm    Post subject: Reply with quote
Hi Al'
I'd bleed till clear and no bubbles. If the master is working properly it shouldn't take many pumps to work through.
My dad got a master cylinder from alfashop about 2 months back.
PostPosted: Tue Nov 24, 2009 2:53 pm    Post subject: Reply with quote
Does anyone know if the clutch master cylinder can be overhauled/repaired/serviced, with a kit or something?
PostPosted: Tue Nov 24, 2009 3:41 pm    Post subject: Reply with quote
There was a new one on ebay recently- might still be there- quite cheap.
I think it's a bit of a slag to replace, so i personally wouldn't want to risk overhaul.
eagle3
PostPosted: Tue Nov 24, 2009 6:16 pm    Post subject: Reply with quote
I don't think they're too difficult to find. Available here for 60-80 euros new.
If you get a new one at least the car won't be out of action for an indefinite period.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Tue Nov 24, 2009 11:01 pm    Post subject: Reply with quote
I am now loosing the content in the reservoir from full line to bottom of clutch master feed in 2 days.
There is no leakage from the inside where the clutch master cylinder connects to the clutch pedal in the foot well. There is no leakage from underneath the master cylinder in the bulk head.
Whilst in 1st gear with the engine running and the clutch in the car started to creep and I had to take it out of gear. When I went to pull away the biting point was just off the floor, I nearly stalled lol, this went back to normal after a while but I was not going to risk it again and keep the clutch pedal in for longer than I need.
Goto page 1, 2  Next
Page 1 of 2
