Crosser than you might imagine it possible to be...
JeremyC
PostPosted: Sun Jan 24, 2010 10:14 am    Post subject: Crosser than you might imagine it possible to be... Reply with quote
Got the old exhaust off this morning, had lunch and went outside to fit the new centre section and the front bracket (the one near the lambda sensor) has been welded on upside down.
Grrrrrr!
'93 Black 33 1.7 16v
PostPosted: Sun Jan 24, 2010 8:16 pm    Post subject: Reply with quote
No way, i feel for you J.C. got hacked off when i wasn't supplied a fitting kit, sent the cat back, i know how you feel!!
JeremyC
PostPosted: Mon Jan 25, 2010 3:17 am    Post subject: Reply with quote
Before I call the supplier I'm going to call Mangoletsi and see how much an Alfa system will be.
PostPosted: Mon Jan 25, 2010 6:40 am    Post subject: Reply with quote
£600 if available lol
JeremyC
PostPosted: Mon Jan 25, 2010 7:33 am    Post subject: Reply with quote
Back boxes £90 inc VAT, Cat is now NLA.
My supplier are collecting the cat tomorrow and will ship a new one out Wednesday assuming not all their stock is wrong. They are also send a back box which was an extra £35 ish.
J.
PostPosted: Mon Jan 25, 2010 10:57 am    Post subject: Reply with quote
What make backbox are you putting on? I think the pattern ones are often 'walker'.
Had a walker on my car when I got it, and it had quite a raspy note. Then fitted a genuine backbox which lasted 6 years/ only about 12,000 miles of which 2 years the car was garaged! -Rotted along the box seam.
Did you suss out the direction of the cat gasket- I think I guessed the last couple of times- no leaks (touch wood).
JeremyC
PostPosted: Mon Jan 25, 2010 11:06 am    Post subject: Reply with quote
Box and Cat are coming from a factors in the Midlands called RSJ who sell loads of stuff on ebay (where I first found the cat).
The box I've just taken off is Walker and I'd have fitted it back on where the cat pipe not solidly rusted / pasted in to it. I could probably get it out but the box isn't that good! At least I can then forget about the exhaust for a few years.
I'm going to fit a new Lamda sensor too.
PostPosted: Mon Jan 25, 2010 11:18 am    Post subject: Reply with quote
A bosch one? Anything else is usually a false economy.
JeremyC
PostPosted: Mon Jan 25, 2010 11:36 am    Post subject: Reply with quote
Yes that's what I was planning, one or other of the local factors quoted me about £45 I think.
Btw, the old cat was completely empty, so whether the old matrix had fractured and headed down the pipe or the previous owner was a bit naughty I don't know. Interesting that it passed an MoT in that state (Al!). If I'd know I'd have fitted cat-less system!
