Posted: Fri Oct 26, 2012 9:10 am Post subject: |
I prefer the look of the top one personally. The bottom one is a bit 'playstation' IMHO.
Is there one available from a late 80's early 90's alfa if they had them (75???) that might match the look and/or brand of what's in the 33?
Posted: Fri Oct 26, 2012 10:27 am Post subject: |
I like the fisrt one too, it's in keeping with my other 2 dials, jeager, I can't find an oil temp one the same  _________________ x2 33 16v
Posted: Thu Nov 01, 2012 6:13 pm Post subject: |
Have a look at my M reg 16v Al, that has oil pressure & temp gauges. (of coarse i'll have to get it running 1st, not long now) _________________ 155 sportpack
Posted: Thu Nov 22, 2012 11:27 pm Post subject: |
She is now back on the rd & running well, both extra gauges work fine  _________________ 155 sportpack
Posted: Sat Nov 24, 2012 8:59 pm Post subject: |
There is a blanking plug next to the oil filter, i removed that & fitted a temp sensor. The oil pressure gets it's reading from the sensor in the middle of the block, i removed the original sensor from the top of the block & replaced it with a bigger type sensor that had an extra screw hole in it, so it kind of converts 1 threaded hole into 2, works a treat.  _________________ 155 sportpack
