Ian M Green Cloverleaf
Posted: Sat Mar 30, 2013 5:07 pm Post subject: Radiator |
My radiator decided to spring a leak today.
I have a spare in my shed so will fit that.
Question
Before I start, is it an easy straightforward job or are there any pitfalls ? _________________ Presntly own
Red Abarth 500c |
The Wombat Alfa Sprint
Posted: Sat Mar 30, 2013 5:30 pm Post subject: |
From limited experience so far, the biggest issue is the amount of room. On my P4, the crank pulley comes very close to it.
Not sure if there is an easy way. _________________ Drivers:
- Green Fiat 20VT Coupe
- Champagne 155 V6
- Winter Freelander
- Mrs Wombats Freelander
Projects:
- Various 33s
- Some 155s
Hibernating for 2015
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v |
Posted: Sat Mar 30, 2013 6:56 pm Post subject: |
Ian,
Take the bonnet and grille off and it comes out dead easy with fan attached out the front of the car.
Posted: Sat Mar 30, 2013 7:02 pm Post subject: |
There you go, the easy way  _________________ Drivers:
- Champagne 155 V6
- Winter Freelander
Projects:
- Various 33s
- Some 155s
- 75 3.0 Cloverleaf
- 155 Q4 Winny
- Red 33 16v |
Posted: Sun Mar 31, 2013 1:01 pm Post subject: |
Well thats the easiest rad Ive ever changed.
And no it didnt involve removing the bonnet (it is easter after all) and grille. _________________ Presntly own
Red Abarth 500c |
Posted: Mon Apr 01, 2013 9:36 am Post subject: |
Woops bit more room on an 8 valver _________________ If it aint broke, fiddle with it until it is!
Posted: Mon Apr 01, 2013 6:14 pm Post subject: |
| john 33_16v wrote: |
Woops bit more room on an 8 valver |
Yep, disconnect the hoses, 2 screws on the fan, remove connections for temp sender, undo the bolt on top of the rad and it slides straight out. _________________ Presntly own
Red Abarth 500c |
Brit01 Gold Cloverleaf
Posted: Mon Apr 01, 2013 11:00 pm Post subject: |
| Ian M wrote: |
Yep, disconnect the hoses, 2 screws on the fan, remove connections for temp sender, undo the bolt on top of the rad and it slides straight out. |
yep beauty of the 8valver. fun engine to work on.
all easy  _________________ S2 33 1988 1.7 QV
