Posted: Sat Jun 22, 2013 6:17 pm Post subject: Linkage Bush |
Just done head gaskets, water pump and belts.
Anyone know where I can get hold of new rubber bushes for the gearbox end of the linkage (1988/9 cars)
(Both my series two 33s' gearsticks rattle a bit in 3rd or 5th gear and it's not gearstick end)[/b] _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Sun Jun 23, 2013 9:52 am Post subject: |
Saw one for sale in France http://www.leboncoin.fr/equipement_auto/359716021.htm?ca=5_s
You'll have to check it's a series 2 model. The one on my '94 33 is a bit shorter and fatter. That one may well be the right one. _________________ Alfa33 QO 1984
Alfa33 1.3i.e. 1994 |
Posted: Sun Jun 23, 2013 10:30 am Post subject: |
Paul,
Also:
http://www.alfaparts.co.uk/detail/alfa-33-s3-gear-lever-linkage-rubber-bush-77.htm
This is for s3 so not sure if ok for your s2, but the part number's the same as eagle's.
I'm selling this so if it's any good PM me mates special
Posted: Sun Jun 23, 2013 10:31 am Post subject: |
Paul,
Also:
I'm selling this so if it's any good PM me for mates special
Bobkelso Alfa Sprint
Posted: Sun Jun 23, 2013 9:55 pm Post subject: |
Thanks Bobkelso, I've sent off for two and will measure them for you. They do look very similar to the S3 ones (thanks John and Eagle), but do have a different part number. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Tue Jul 02, 2013 2:12 pm Post subject: |
bush - code 60502642
length 38mm
ID 12mm
OD 19mm
So it would seem to be the same except 3mm longer. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Tue Jul 02, 2013 8:59 pm Post subject: |
Ok thanks,
yes it seams the 89-90 version
is only a little longer (+3mm)
than version 90-94..
Probably is adaptable. _________________ Alfa 33 |
Posted: Wed Jul 03, 2013 9:09 pm Post subject: |
I have a spare new one for my '94 33. I'll have a look at it. Gritsop kindly got me two from Greece a few years back.
Not sure at the moment when the linkage was modified. _________________ Alfa33 QO 1984
Posted: Sat Jul 06, 2013 6:43 pm Post subject: |
Having compared the two side by side yes if you shave 1.5mm off each end you'd have a series 3 bush. _________________ Alfa33 QO 1984
