non starting 33. starter motor exciter wire not got enough..
Goto page 1, 2  Next
PostPosted: Sun Jun 14, 2015 12:12 pm    Post subject: non starting 33. starter motor exciter wire not got enough.. Reply with quote
Hi Guys and Dolls.
My 33 wont start unless I turn the ignition on and use a wire direct from the + of the battery to the exciter wire on the starter motor.
I have cleaned the contact on the starter motor and if I connect my DMM to it, when I turn the ignition I am getting 12v.
I assume I am getting a current drop but need help in where to start, thanks.
eagle3
PostPosted: Fri Jun 19, 2015 7:10 am    Post subject: Reply with quote
Could be faulty ignition key switch.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Fri Jun 19, 2015 2:11 pm    Post subject: Reply with quote
Don't think so as I'm getting 12v on the exciter wire when it's turned
ZeNiTh-PbArM
PostPosted: Sat Jun 20, 2015 10:33 am    Post subject: Reply with quote
Sure, but the point is, you measure 12V at no load, i.e. with the wire unplugged from the starter motor.
If you measure voltage while the wire is connected to the solenoid, there will be current flowing and any resistance upstream will cause a voltage drop proportional to the current.
With no current (disconnected) there is no voltage drop
Try shorting at the ignition switch and see if it cranks ok
zp
eagle3
PostPosted: Sun Jun 21, 2015 6:01 am    Post subject: Reply with quote
Just put a replacement switch on my C15 diesel van. Starting was a bit hit and miss, getting gradually worse. Pre-heating was fine but the exciter bit(last turn of the key) was obviously problematic.
I had a lead in the car to connect the exciter terminal direct to the battery + terminal to start it if it didn't want to. New(ish) switch sorted it.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Mon Jun 29, 2015 4:29 pm    Post subject: Reply with quote
I unplugged the ignition switch block connector and reconnected it a few times.
Seemss ok atm
PostPosted: Sat Jul 25, 2015 12:05 pm    Post subject: Reply with quote
Everything is all good, not had a starting problem since Smile
PostPosted: Tue Sep 01, 2015 3:39 am    Post subject: Reply with quote
Well it did it again. Evil or Very Mad
eagle3
PostPosted: Thu Sep 03, 2015 7:37 pm    Post subject: Reply with quote
Can you get hold of another ignition switch + key(s)?
All but the latest series 3 have a 3 pin electrical socket I believe. My 1994 one has a four pin socket for anti-theft device.
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
Johnpm1967
PostPosted: Sat Sep 05, 2015 10:52 am    Post subject: Reply with quote
Al,
I have 3 spare ignition switches and steering column. They are all from series 2 so if yours is 3 pin set up they could work.
Shout if I can help.
PostPosted: Fri Sep 11, 2015 10:52 am    Post subject: Reply with quote
Thanks Guys, Im not sure if its the ignition switch, as there is power to the exciter wire when turning, although not enough to crank???
Happened again last night Twisted Evil
PostPosted: Sat Sep 12, 2015 11:13 am    Post subject: Reply with quote
Have you got an aftermarket alarm Al?
PostPosted: Sat Sep 12, 2015 9:41 pm    Post subject: Reply with quote
yes but it's not that, been there before lol. there is power to the exciter wire when the key is turned but not enough to crank.
I am not getting email notifications
PostPosted: Sat Sep 12, 2015 10:00 pm    Post subject: Reply with quote
Only saying because I had the very same issues with mine. I disconnected the immobiliser on the alarm which was basically two wires that cut power to the starter. Never had another problem starting again. Could be worth doing to eliminate it.
PostPosted: Sat Sep 12, 2015 10:22 pm    Post subject: Reply with quote
Have you had a look inside the solenoid? Not sure you can dismantle on the 33 but if you're getting 12v on the exciter then maybe that tends to a solenoid problem?
Maybe also an amperage problem? Maybe voltage is OK but not enough amps to crank?
Sell it.
PostPosted: Sun Sep 13, 2015 6:05 pm    Post subject: Reply with quote
Don't sell it. An Alfa 33 beat all-comers today at Croft Racing Circuit. Very Happy
Hope you can sort it Al. Don't know what to suggest.
Johnpm1967
PostPosted: Sun Sep 13, 2015 6:34 pm    Post subject: Reply with quote
How annoying. If the starter motor on the 3 is the same as the 2 then I have spare you could borrow to test the solenoid theory. Only problem I am not close.
PostPosted: Mon Sep 21, 2015 2:39 am    Post subject: Reply with quote
thanks for the suggestions guys.
I have eliminated the alarm by temporarily bypassing it, so that isn't the problem.
I believe there aren't enough amps because when I connect a wire direct from the +battery to the exciter wire on the starter motor, it works.
Are there anymore connections to clean between the ignition barrel and the exciter wire connection on the starter motor?
STILL NOT GETTING EMAIL NOTIFICATIONS Sad
PostPosted: Mon Sep 21, 2015 7:33 am    Post subject: Reply with quote
If that's the case Al then simply rewire the exciter wire via the ignition switch with an in line fuse. Something is clearly breaking down in the original part of the loom.
PostPosted: Mon Sep 21, 2015 2:20 pm    Post subject: Reply with quote
I been considering that lol but I'd like to get to the cause though
ZeNiTh-PbArM
PostPosted: Mon Sep 21, 2015 4:14 pm    Post subject: Reply with quote
If you are looking for the root cause you may want to look for :
1. Harness terminal mating with solenoid tab. Crimp connection to the wire gets oxidized, and the terminal itself can loose clamping force. I had an intermittent non-cranking issue, always in hot condition, which I definitely cured cutting this terminal and crimping a brand new one instead
2. big square connector between battery and heater fan. One wire is the starter one
3. ignition switch square connector below steering column
4. ignition swith itself
zp
eagle3
PostPosted: Tue Sep 22, 2015 1:23 am    Post subject: Reply with quote
Ignition switch still favourite with me..
Alfa33 QO 1984
Alfa33 1.3i.e. 1994
PostPosted: Wed Sep 30, 2015 2:08 am    Post subject: Reply with quote
This is hard to get to the cause as I only drive once a week and it's intermittent.
I drove today and it started on the first leg of the journey and after putting some fuel in.
On the return journey all was good until I made a stop. then it didn't work.
This time I checked my temp alarm bypass, don't need it when i'm driving it lol and it started.
Lee, this is weird because when the alarm is in use it doesn't cut power to the starter. It will just crank but not start.
ZeNiTh-PbArM
PostPosted: Wed Sep 30, 2015 8:32 pm    Post subject: Reply with quote
When you checked, did you by chance open the hood? If yes, faulty connections may have cooled down at the same time...
PostPosted: Thu Oct 01, 2015 2:07 am    Post subject: Reply with quote
I parked, turned the engine off, got out for a min, got back in and it didn't start. I opened the bonnet and only moved my bypass connector. I will leave the alarm connected whilst I'm driving from now on.
thanks for all the suggestions guys.
Goto page 1, 2  Next
Page 1 of 2
