MMOEXP: Arc Raiders often send you searching for various
Ludwighench
PostPosted: Tue Nov 25, 2025 8:47 am    Post subject: MMOEXP: Arc Raiders often send you searching for various Reply with quote
Quests in ARC Raiders Items often send you searching for various items across its expansive maps, and Broken Monument is no different. In this quest, you'll need to round up a ration, compass, and tape to take back to Speranza. However, if you've visited the Scrapyard where these items are located but are still having trouble rounding them up, you're not alone. We'll tell you where to find the items below so that you can complete the Broken Monument quest.
Before setting off on this journey, though, be aware that you need to extract with the items that you find during the quest. As such, you'll want to come prepared to fight your way out if necessary. Bring good guns with you, and maybe even equip a Looting Mk. 3 augment if you have one, as it will grant you three safe pockets. If you place the items in your safe pockets, you won't lose them if you end up killed during the raid.
When you're ready to track down all of the items, you'll need to head down to the Scrapyard POI on the Dam Battlegrounds map. This location is found on the southern edge of the map in a forested area.
When you arrive, look for the field depot here. It's easy to spot, as it's a large structure type you've probably visited in the past for quests in other areas on the map. Head inside to find a small box on the ground against the interior wall. Loot this box to find the Old Field Rations.
From the field depot, head south slightly until you spot some large tubing come out of the ground. Here, next to one of the tubes, is another box. Loot this box for the First Wave Video Tape.
Heading south slightly once more, you should spot a lot of destroyed vehicles. You can cross atop these and drop into an area between them. Here in the corner is the final box, which you can loot to snag the First Wave Compass.
Now that you've obtained all of the items you need, you'll need to extract with them to complete the quest. You best bet is likely to head to the Red Lakes Balcony Lift to the northeast. It's a fairly popular spot, but if you scout ahead a bit and play ARCR Coins for sale things safe, you should be able to get back to Speranza in one piece. Best of luck, raider.
suman65
PostPosted: Tue Nov 25, 2025 8:49 am    Post subject: Sexual Service Provider Reply with quote
If​‍​‌‍​‍‌​‍​‌‍​‍‌ you want an energetic and intimate night out in the city, Noida Call Girls are the ones to make it happen. These sexy and excited call girls are the perfect people to do the job and they are definitely worth your money. They are simply equipped to do so whether you are a fan of slow and romantic or wild and crazy style of lovemaking. So, what are you waiting for? Just book the best call girls in Noida, and have a time of your life.
