phil Guest
Posted: Fri Dec 05, 2003 1:56 am Post subject: cracked bumper |
I have cracked my front bumper after hitting a fox. Bumper still in one piece, but with crack across the front. How to fix? what type of glue or should i just replace.
Ta |
Posted: Fri Dec 05, 2003 8:04 am Post subject: |
Hi Phil
I have welded some bumpers and other plastic bits using an electric soldering iron. Iether use filler after welding or cut thin strips of a similar plastic and use like a brazing rod in conjunction with the soldering iron. Best of luck.
