Pimp_Dudu Alfa Sprint
Posted: Fri Dec 05, 2003 11:08 am Post subject: coughing problem... |
| my car has this very weird problem of "coughing" when cold or wet...it seems as the engine doesn't get enoug fuel or the spark plugs don't work...but...i changed the spark plugs...i changed the cables from the distributor...i changed the distributor...and my injection pump is working perfectly...but i still have problems....and this usually happens when im down to about 5-10leters of fuel...the problem usually occurs when i'm on a constant speed...but sometimes when its really cold or wet also when i accelarate...does anybody know what the problem may be?????I did once ask this question before... |
P4 Paul Alfa Sprint
Posted: Fri Dec 05, 2003 1:19 pm Post subject: coughing |
| have you checked you fuel filter?,because as these 33's get older,the fuel tank rusts on the inside,and may have dragged some with it blocking the flow as such. |
