Morgan Alfa Arna
Posted: Fri Jun 04, 2004 6:41 am Post subject: Could S3 33 adjust camber? |
Is it easy to adjust camber? |
Posted: Fri Jun 04, 2004 8:57 am Post subject: |
No it's not.
At the front you either buy adjustable lower suspension arms or chop and weld the current arms. Or mess around with moving the top mounting holes, I personally would avoid this route as the stresses will be out of the design spec. and could lead to the top collapsing.
The back is even tougher due to the beam axle, more serious welding required.
I take it your car is lowered! |
GaryUK Guest
Posted: Fri Jun 04, 2004 9:01 am Post subject: |
That was me above |
alfaqv33 Alfasud
Posted: Fri Jun 04, 2004 9:09 am Post subject: |
look on the following link, you can by adapters to change your camber (at the front) http://www.biesheuvel.nl/
You have to searh, but in a few minutes you will found it! |
Posted: Fri Jun 04, 2004 9:53 pm Post subject: camber adjustment |
It is relatively easy to adjust the camber on 33s.At the front all you have to do is elongate 3 of the 4 mounting holes at the bottom of the strut and pivot the hub on the 4th. At the rear use shims behind the stub axle carrier. I won't go into a blow by blow account of how to do it but if you can't work it out from above description and looking at your car then maybe you shouldn't be attempting to do it! |
