33.1.7ie turismo Guest
Posted: Tue Oct 05, 2004 1:31 pm Post subject: Paintwork |
Hi all
I have a red 33, and the paintwork is looking a little faded, almost a pinky colour. are there any easy ways (apart from a respray) to get the red colour back?
Cheers! |
Posted: Tue Oct 05, 2004 2:12 pm Post subject: |
Easy if you do it yourself, no. Long time term no.
Usual way is to wax or polish and wax it. Depending on state of oxidation/fade it will last from 1-3 months. _________________ Tino Vatavuk
Posted: Tue Oct 05, 2004 5:19 pm Post subject: |
thought that may be the answer |
Marcin Alfa Sprint
Posted: Wed Oct 06, 2004 7:16 am Post subject: |
my alfa has got quite pink over the years, but when I give it a good polish, the red color returns as it was brand new. Ok, almost brand new. And anyway, it doesn't hurt to give your alfa a little bit of wax every now and then
Marcin |
Laki Alfasud
Posted: Wed Oct 06, 2004 9:44 am Post subject: |
Same for me...No real sullution...new paintjob or polishing.... _________________ -- ALFA ROMEO 33 Q4 --
Posted: Wed Oct 06, 2004 11:42 am Post subject: |
Well polishing and waxing can fool people if done properly. Some days ago I did a polish and wax to my Alfa (red) which over the years I had faded somehow. I used Armor All brand name. A week ago in the annual HAROC assembly many participants were asking me if I had repainted the car
So give it a try - the results will be better than today, and if possible use cover sold by auto accessories. It will protect your car and see that within a year of use the wear of it from the sun will be such , that the material will tear away and collapse.
I will post photos on order to see the difference.
Posted: Wed Oct 06, 2004 12:09 pm Post subject: |
ace, thanks for the advice guys! do any of you have any recommendations as to the best polish to use? i have heard the t-cut colour polish is good?
also how do i show pics? i want to show u all my new car
[/img] |
Posted: Wed Oct 06, 2004 2:13 pm Post subject: |
In order to show pics you need to host them somewhere - then when writing your post you can include the URL of the pic.
The forum itself does not have the capability to host them.
I have also heard about T-Cut and words say that it is a good product.
But in my country I could not find it.
Laki Alfasud
Posted: Wed Oct 06, 2004 4:19 pm Post subject: |
I use SONAX Also does the trick _________________ -- ALFA ROMEO 33 Q4 --
burgo90 Alfa Sprint
33 1.7 ie Turismo Alfasud
Posted: Wed Oct 06, 2004 8:35 pm Post subject: |
burgo90 wrote: |
g3 is unbeatable, we use g3 everything in the bodyshop at citroen |
whats G3 can i buy it in the UK? |
burgo90 Alfa Sprint
Posted: Wed Oct 06, 2004 11:30 pm Post subject: |
nice one! i'll b getting some of that 2moro and teach those pinks panels a lesson !!
will those yellow polishing cloths u can get in halfords be good enough or can u recommend some better ones? |
Posted: Thu Oct 07, 2004 4:14 pm Post subject: |
right, had a bash with the t-cut colour polish i bought and its worked really well! v happy, i think with a couple more coats it will look great
problem solved. thanks for all your advice guys, was worried i would need a respray, so you've saved me a fortune!!
cheers
chris |
paddy granger Alfa Sprint
Posted: Thu Oct 07, 2004 4:55 pm Post subject: |
Umm, hold your horses.
T-Cut is great for removing the flat pink layer and small scratches. Once your car is shiny, you should only use normal or coloured wax. T-cut actually removes thin layers of paint (you may notice that your duster turns into the same colour as your car), and should only be used to restore the paint to its correct colour and or gloss. It cuts back the layers until you are happy with what you see. If you continue cutting back, you will eventually run out of paint.
Once you have cut back the flat layer, I would recommend Valma for the coloured wax (they have a great range of different colours), and Turtle wax for the clear wax. Do not confuse Turtle T-cut with the wax products they offer.
Patrick |
Posted: Thu Oct 07, 2004 6:51 pm Post subject: |
hi patrick
i used the t-cut coloured polish, which is red. is this not the same as t-cutting and waxing at the same time with a coloured polish, as this is how it is promoted?
http://www.incarshop.co.uk/acatalog/T_Cut_Coloured_Polish.html
its the 3rd one in the list
should i also use a clear wax too?
cheers |
Posted: Thu Oct 07, 2004 8:16 pm Post subject: |
There are two categories of products, the "Pre-Wax cleaners" and the "Waxes & Polishes". Your product falls into the "Waxes & Polishes" category.
It should be OK to use, as it isn't primarlily designed to cut back the paint, but rather to only remove the oxidized layers whilst also waxing. It has a very weak cutting characteristic compared to pure T-cut.
A similar product is offered by Turtle Wax called "Color Back Finish Restorer & Car Polish".
If your paint is shiny after the initial treatment with the T-cut product, I would suggest you use a clear wax, such as Turtle Wax "Super Hard Shell", or "Express Shine" which is really easy and quick to use.
There is a member on this forum called Gary who has some professional experience in the paint industry, hopefully he will also contribute to this thread.
Patrick |
Posted: Fri Oct 08, 2004 11:51 pm Post subject: |
its seems to be looking pretty mint now, so i think i will invest in some wax to finish it off. the "super hard shell" sounds like the one i will go for. thanks for ur advice patrick |
James Granger Alfa 33
Posted: Fri Oct 08, 2004 11:57 pm Post subject: |
Paddy and I cut back our faded paint 5 years ago as it was seriously pink. The result was astonishing, and the glossy red has lasted to this day. In fact the paint has looked increasingly good for the past 2 years.
Before:
Now:
The paint actually looks better than on our newer 147!
Our secret is that we garage the car and wax it on a regular basis.
I've heard that if you T-cut a faded car and use it on a daily basis - leaving it outside in the sun and in the rain - it'll fade again in a short period of time. |
Posted: Sat Oct 09, 2004 12:26 am Post subject: |
OMG! thats some difference! what did u use (apart from the wax) also, i think those alloys (155 v6?) suit the car really well |
Posted: Sat Oct 09, 2004 10:08 am Post subject: |
Here's my previous car (also my first car), a 1988 Mitsubishi Cordia:
That photo was taken as soon as I drove the car home after buying it.
I bought some T-cut stuff, the coloured kind that turns your application cloth pink and your polishing cloth pink and your hands pink, and leaves pink dust behind once you've polished it off.
But the photo below is from when I sold the car (I crashed it as you can see, just enough to make it not economical to repair):
The photos aren't completely fair, but the paint improved with some T-cut and probably a wax of some sort.
And James, note how my pictures are reasonably sized and don't take forever to download. |
Posted: Sat Oct 09, 2004 8:58 pm Post subject: |
33 1.7 ie Turismo wrote: |
Just T-Cut and wax! Yep the wheels are from a 155, but from the 2.0 Super widebody version. They may well have been fitted to the V6 as well. |
Marcin Alfa Sprint
Posted: Mon Oct 11, 2004 7:36 am Post subject: |
James / Paddy,
what eles did you do to your car (besides the polishing)? I see that mirrors and bumpers changed color... The rims have already been mentioned
Looks great
Marcin |
Posted: Mon Oct 11, 2004 4:32 pm Post subject: |
James Granger wrote: |
James you are one entering car on 1st picture? _________________ Tino Vatavuk
