Knight Guest
Posted: Thu Oct 14, 2004 1:14 pm Post subject: 1.7 standard carb sizes, 36 or 40??? |
I found this following quote on the Alans 1.7 16v conversion site:-
"The 8v engine that is being compared here is the twin Weber 36IDF or Dell'Orto 36DRLA carburettor type available in 1.3, 1.5 and 1.7 litre capacity versions, in the Alfa Sud, Sprint and 33 models"
So am I right in thinking that ALL the 1.7 carbed engines are fitted with 36mm carbs????......if so where are people getting their 40mm carbs from????......surely they arent buying them new, the last time I saw a new one it was about £300 each......ouch!!!! |
Serpent33 Alfa Sprint
Posted: Fri Oct 15, 2004 1:18 am Post subject: |
1.7qv S2 comes with 40. Not sure about earlier one. _________________ Each time I speed I say, "Dear lord, make me fast and accurate..." |
lesthegringo Alfasud
Posted: Fri Oct 15, 2004 12:32 pm Post subject: carb sizes |
depends on the engine - early 1.7 ov engines were fitted with 36IDF webers (or their Dell'Orto equivalents) butn later engines were fitted with 40IDFs, and often had 2mm larger inlet valves too.
Les |
dave Alfa Sprint
Posted: Sun Oct 17, 2004 3:18 pm Post subject: carbs |
hi the later ser 2 1,7s are fitted with 40s and ser 1.5tis are fitted with 36s either webbers or dellortos they did a 1350 twin carb with had smaler carbs on and some early i.5 single carb models i have both webbers and dellortos available
dave _________________ alfadave1@btinternet.com
VW TOURAN 59 PLATE WHITE WITH TINTED WINDOWS AND ALLOYS MR BLING
CHEVY MATIZ |
