jattsta Alfasud
Posted: Tue Oct 26, 2010 11:12 am Post subject: ABS |
I was wondering if any of you guys has fitted aftermarket ABS to your 33
I understand it was available on P4'S
I have 4 pot willwood disks all round at the moment and the brakes are good but ABS would always be a plus point |
johnboy 16 Valve
Posted: Tue Oct 26, 2010 11:34 am Post subject: Re: ABS |
jattsta wrote: |
ABS is for girls  _________________ WODA WE NEED? MORE POWER!!
1999 freestyle superjet |
jattsta Alfasud
Posted: Tue Oct 26, 2010 11:41 am Post subject: |
LOL
Fair nuff |
Ian M Green Cloverleaf
Posted: Tue Oct 26, 2010 3:21 pm Post subject: |
If you put it back to standard that is as good as ABS.
Mine never lock up cos they're shite _________________ Presntly own
Red Abarth 500c |
Posted: Tue Oct 26, 2010 7:47 pm Post subject: |
lol,
You guys crack me up, yup the standard brakes on the 33's are not very good, if looked after they can be ok.
I experimented with a few options many years ago and finally got mine to work very well, when pushed hard I only ever got brake fade once and it came back really quick. I tried mintex and ferrodo pads, red dot 40 or 60 grooved disks.
Mine as they are will lock up the fronts and the front can drop, showing the brakes are working, there is still room for improvement.
I am using ferrodo pads and stock disks, you need to make sure the play in the rear is taken up first and that if the car is lowered the brake bias adjuster has been adjusted, something I need to do, hence the room for improvement. _________________ x2 33 16v
Posted: Wed Oct 27, 2010 11:19 am Post subject: |
Yes, the 33 comes with dry weather anti lock brakes as standard.
The real 33 ABS system was fairly crude, and suspect it would be a pig to upgrade a non ABS car to use it. The ABS versions used rear disks which on a 2wd car would be the most obvious issue.
jattsta Alfasud
Posted: Wed Oct 27, 2010 11:56 am Post subject: |
I think id stay with my current set up
The willwoods are great at stopping the damn thing.
The other thing that i would of liked to have was A/C but that too seems a costly waste of time too |
Posted: Wed Oct 27, 2010 3:21 pm Post subject: |
Somewhere around I have the manual for fitting the air conditioning scanned in. If it would help I can dig it out.
Posted: Wed Oct 27, 2010 5:49 pm Post subject: |
Have a chat with Rich B on here, he is re building his 33 & fitting air-con. It's a pig of a job! i've stripped 3 16v cars that have had it, there is loads to it. _________________ 155 sportpack
Posted: Wed Oct 27, 2010 6:31 pm Post subject: |
Cheers Keith but it would really be of no use to me as i wouldnt have a clue where to begin.
What im after is for me to chuck a wad of notes and for the job to be done lol
Ill give Rich B a shout perhaps |
jattsta Alfasud
Posted: Wed Oct 27, 2010 6:32 pm Post subject: |
The above post was obviously mine-forgot to log on! |
JeremyC Gold Cloverleaf
Posted: Wed Oct 27, 2010 6:34 pm Post subject: |
Standard brakes are fine, on the anchors all the time is not the quickest way chaps, use the car's balance. _________________ '93 Black 33 1.7 16v |
