Posted: Sun Mar 19, 2006 4:59 pm Post subject: P4 Wiper Relay |
Could someone please tell me where the windscreen wiper intermittance relay is on a P4. Thanks. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Edward Alfa 33
Posted: Wed Mar 22, 2006 7:56 pm Post subject: |
Paul,
There was someone else on the forum that lodged a picture of where the relay was on the P4. From rough memory it was on the LHS as you look at the car from the front - near the heater - but that could be a bit of a bad guess. Have you looked in the search function. It was a page from a P4 specific suppliment manual.
I may see if I can find it in all my paperwork - alternatively I could just pull out all the relays in sequence until it stopped working on my one - perhaps not. I will see if I can find it in all my documents.
Edward. _________________ The faster the better. |
Posted: Wed Mar 22, 2006 10:26 pm Post subject: |
I pulled out all the relays and they just kept on going! I don't have any relays on the left hand side. Maybe that's the problem  _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Posted: Thu Mar 23, 2006 8:24 am Post subject: |
Hi Paul,
it is not relay at least not usual one. It should be in plastic housing, but higher and with step near its base. TVR/12 or something like it is writen on it.
When you look at fuse box, on sides there are 2 columns of relays, in between there are few columns of fuses. At end of mid fuse columns there are 2 solenoids first is for wipers, second is for side lights.
On my P4 it is black, it is only one in second "relay" column, from left.
Hope it helps, cheers _________________ Tino Vatavuk
Posted: Thu Mar 23, 2006 10:14 am Post subject: |
Yes thanks, I wondered if it might be somewhere there. Will go and check it out. Much appreciated. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
Edward Alfa 33
Posted: Thu Mar 23, 2006 10:32 am Post subject: |
Paul,
Are you going to the Spring Alfa day? _________________ The faster the better. |
Posted: Thu Mar 23, 2006 10:38 am Post subject: |
Absolutely, that's the plan. Not sure whether to bring P4 or white series 2. _________________ Owner's Club 33 Registrar. Now from P4 & S2 1.7 QV
