REALIGNMENT OF WHEELS
BILL
PostPosted: Thu Aug 21, 2003 7:08 am    Post subject: REALIGNMENT OF WHEELS Reply with quote
Im taking my car (33 1.4 ie 1992)for a realigment of wheels and i want to know if the 16V uses the same data for the camber caster e.t.c.
Becoase i have 14inc wheels, the shocks absorvers that the 16V uses.Or should i stick to the data for the 1.4ie.
Thanks in advance
gritsop
PostPosted: Thu Aug 21, 2003 4:00 pm    Post subject: Reply with quote
Bill, can you restate what you have written because i cannot understand what you want to ask !?
Thanassis Gritsopoulos
BILL
PostPosted: Thu Aug 21, 2003 4:55 pm    Post subject: Reply with quote
After fitting new tyres im taking the car to the mechanik to check camber caster toe in .Are the mesurements the same for the 16V and for the 1.4?
gritsop
PostPosted: Thu Aug 21, 2003 9:48 pm    Post subject: Reply with quote
According to the workshop manual for the Alfa 33 s2 vehicles with engines of 1.2, 1.3 , 1.5, 1.7 the figures are the same for all cars.
toe out: 4 +-2'
toe out angle : 10'
camber angle : -1 degrees +-30'
caster angle: 2 degrees +-30'
Note: these figures are considered with static car load (about 75 kg in the passenger seats plus about 50kgs luggage)
Hope this helps.
